70 Cutlass manual console looks like ???
What does the 70 manual console look like ??
I'm going to a manual in my car, so I'm going to sell my mint condition console.
I'm just not sure if I want to replace it with a manual console or leave it empty.
Anyone got any pics they can post of what they look like ???
It looks just like the automatic console for 1970-72. The M/T version uses an adapter that fits over the top and holds the shifter boot. The woodgrain inserts are different because of this. As with the dual gate, the console is scored on the underside for the necessary cutout to use it as an M/T console.
And....you can buy all the parts to make the conversion on the console from The Parts Place.
So DON'T SELL YOUR NICE CONSOLE!!!!
Of course, this all assumes you are using a shifter/trans setup that has everything (like the shifter) in the stock location.
http://www.protoyzinc.com/product.cfm?id=12
Finally found a picture.
I've seen one of these @ The Parts Place.
I had no idea it was an Olds console tho. They are definitely different.
It's not the same console. 90% similar, but that shifter boot section
is wider then then the narrow sections in front and behind like the Auto
Consoles use the entire length.
I can't possibly see a conversion being possible without hacking the center
of the auto console to open it up more. I'd rather sell it and have no console
then do that. Besides, I really don't know where the shifter will end up yet
for the transmission I'm going to be using. Borg Warner T-56 6-Speed.
The parts place is where I normally go since it's 45 mins from my house.
I can't possibly see a conversion being possible without hacking the center of the auto console to open it up more. I'd rather sell it and have no console then do that.
Besides, I really don't know where the shifter will end up yet for the transmission I'm going to be using.
Okay, so it IS the same console.
So I have to do some cutouts on my existing auto console to adapt those pieces in is what you're saying. That makes sense. I just couldn't see it being a drop on top and go sort of thing.
Thanks for da info. Guess I'm not doing anything til spring anyways.
I have a 4 speed console question. I ran across a craigslist ad for a 4 speed console out of a 72. He makes a point of stating that it has the correct grayed-out rear lens unlike the white lens in the automatic console. First time I have ever heard this but I am learning new things about these cars everyday. I was hoping Joe or another expert could weigh in. Thanks guys.
http://pittsburgh.craigslist.org/pts/1964503246.html
GAOldsman
August 19th, 2011 02:06 PM
57 rocket
February 2nd, 2011 07:03 AM
