Quarter panel window trim attachment
Old May 11, 2024 | 04:35 PM
Found out my 72 uses just a little double sided tape to put the hardtop door window to quarter window seal piece on. Rolling the window down caused the rubber molding to get under it and flip it off the window. The other one is not stuck on very well either.
I am thinking 3m double sided emblem tape for most of the length. Is that correct to reattach with?
Old May 11, 2024 | 04:38 PM
The piece in the box. Not my car.
Old May 11, 2024 | 06:37 PM
Subscribed, if you don't mind me piggybacking. I have exactly the same problem looking for a solution. Double-sided tape never occurred to me -- I wouldn't think it would be sticky enough.
Old May 11, 2024 | 07:26 PM
mrolds69's Avatar
The correct thing is door setting channel tape. It's like a butyl tape, no glue. You can see it on pg 113 of the AMES GTO catalog. It's 2.00 a foot, I think it's the thinner one, I always buy extra it's good stuff to have. You lay it in the channel, or put it on the glass edge, and gently beat or force the channel on the glass. It's cheap and done forever. You have to make sure the door jamb seal is split right, too.
Old May 12, 2024 | 04:37 PM
BackInTheGame's Avatar
This is the right way to do it. The Fisher Body Manual (IIRC), or maybe it was the Parts Book, has the correct dimensions, thickness and width, for the butyl rubber tape. You can trim the width as appropriate, if you can't find the correct width. As mrolds69 says, there is no adhesive used. To make installation a little easier, spritz with water the inside of the tape on the glass side. Works like a champ. Be careful with alignment top-to-bottom. If you install it too low or too high on the glass, you have to disassemble and try again.
Old May 13, 2024 | 12:35 AM
X3. Just Google glass setting tape
Old May 13, 2024 | 06:39 AM
I have.
I have both thicknesses on the way from Ames this morning. Will report back.
Old May 13, 2024 | 07:24 AM
Is Ames the only place to get it? A NAPA in the next town has a body and paint supply section. I was thinking of taking a road trip over there.
Old May 13, 2024 | 07:28 AM
Amazon Amazon
Old May 13, 2024 | 08:20 AM
Thanks, Joe. Lots of choices there. I'm gonna go ahead and guess FlexSeal probably isn't the way to go.
Old May 13, 2024 | 08:48 AM
I need the car to be used this weekend, so I had Ames put the heat on it for shipping.
Old Jun 12, 2024 | 05:04 PM
John, how'd this work out for you?
Old Apr 21, 2026 | 09:15 AM
72OldsCut<'s Avatar
Barry
Can this channel and glass setting tape be removed and re-installed without removing the quarter window glass from the car?
firstoldsmobile
Body work
Jun 29, 2022 07:55 PM
jarcher442
Dec 29, 2021 05:08 PM
firstoldsmobile
Body work
Dec 17, 2020 04:37 AM
olds70supreme
Oct 16, 2014 05:04 PM
garys 68
Jan 16, 2011 08:33 PM
