69 Cutlass S convertible windshield trim
Old Dec 14, 2022 | 11:28 AM
lala5818's Avatar
1969 Cutlass S convertible. I’m putting the trim back on after the windshield was installed. When installing the vertical trim on the sides (drivers/passenger) does the trim bolt directly to the body or does some sort of sealant or butyl tape go between?
Old Dec 14, 2022 | 08:04 PM
70Post's Avatar
The wide stainless piece (not the piece that holds the weatherstrip) typically had a bunch of grey rope calk on the underside of the part where the attaching screws are. I've pulled a few of those and it was always a struggle to "peel" the stainless away from the metal A-pillar. Of course you want them to fit flush but the rope calk would thin out as the attaching screws were tightened down. Can't tell you exactly HOW much but they were fairly generous in the application.
Just look at your pic and imagine where water would migrate under the piece and into the screw holes.
The w/strip stainless channel itself will have a strip of thin black closed cell foam tape on the underside...up and down its whole length.
65droptop
Mar 26, 2022 12:33 PM
Jacoz70442
Mar 7, 2021 06:46 PM
maineolds
Nov 28, 2020 06:44 AM
luima408
Ninety-Eight
Mar 9, 2011 10:57 AM
marinus_
Apr 30, 2010 12:05 PM
