Rear seat back removal
Old Oct 22, 2021 | 01:16 PM
Larrysolds's Avatar
As a winter project I am going to have the seats in my 64 cutlass convertible redone. I'm removing the back seat and have the seat bottom removed. I have removed the screws on the seat back but it does not want to come off . Is it attached somewhere else ?? Any help would be greatly appreciated.
Old Oct 22, 2021 | 01:26 PM
RAMBOW's Avatar
Ben
There are 2 or 3 hooks near the top of the steel support the upper cushion rests against, the frame needs to be pushed straight up (maybe slight pressure rearward at the top to help release from the hooks) and it comes up and out.
you will probably need to remove the armrests to get it out, but i'm not 100% positive
Old Oct 22, 2021 | 03:09 PM
Yellowstatue's Avatar
Check for one or two screws at the top installed from back to front.
Old Oct 22, 2021 | 06:18 PM
harleyrules's Avatar
Just push in and up and it will release from the 2 mounting tabs on the back. You don't need to remove the armrests. Just some even pressure and it will come out.
Old Oct 23, 2021 | 04:09 AM
Larrysolds's Avatar
Thanks for all the quick replies. I'm going to try it today.
Larry
Old Oct 23, 2021 | 08:15 AM
Hopefully you’ll find some vintage coins under the seat. 😊
Old Oct 23, 2021 | 12:29 PM
Larrysolds's Avatar
Got the seat our thanks to the responses on this forum. Sadly no rare coins or any other treasures . I was hoping to find the build sheet.
Thanks again to those who replied to this post.
Jandk
Jul 4, 2015 11:45 PM
dave84
Jan 23, 2014 08:12 PM
Hawk1061
Apr 11, 2013 08:57 PM
ACID64
Sep 16, 2011 03:07 AM
Chumley
Oct 31, 2006 04:44 PM
