dome light/map light options for a 64 F-85
Old December 7th, 2018, 03:42 PM
therobski's Avatar
I would like to get some ideas on a dome light/map light options as well as some courtesy lights under the dash by the driver/pass kick panels.This F-85 Granny ordered back in 64 was down to the bare bones, no seat belts, just an am radio and heater, base dome light, no rear arm rests, vinyl floor etc. Appreciate any and all ideas on parts selections!
therobski is offline
Old December 8th, 2018, 06:26 AM
Front seat belts were standard equipment, however you could delete them for an $11 credit. Rear belts and deluxe belts were extra cost options. The dome lamp was standard equipment, however on the base F-85 it only operated from the headlamp switch. If you wanted the door pin switches you needed to order RPO Y67 Deluxe Interior (The F-85 Deluxe and Cutlass models came with these switches standard). The under dash courtesy lights were optional under RPO U29 on all models except convertibles, where they were standard to replace the dome light. RPO Y60 got you the trunk, glovebox, and ash tray lights. There was no map light option.
joe_padavano is offline
Old December 8th, 2018, 09:45 AM
therobski's Avatar
Thanks for the information Joe....
therobski
August 5th, 2018 11:10 AM
therobski
August 3rd, 2018 01:09 PM
pfergy600
August 14th, 2014 11:26 AM
scott_442
June 13th, 2012 07:21 AM
marcocutty82
September 4th, 2011 11:36 PM
Quick Reply: dome light/map light options for a 64 F-85
