Headliner for 1980-85 Delta 88
Old July 28th, 2017, 06:25 PM
car_designer's Avatar
Wondering if anyone makes a headliner for my 1983 Delta 88. I'm finally taking some time to look at it again and one of the first things on my list is to replace the headliner.
If not, I'll look at a local shop.
car_designer is offline
Old July 29th, 2017, 05:06 AM
Rocketowner's Avatar
Maybe I'm thinking wrong ,but don't that model have the foam backed cloth,that you take the headliner board out and scrape off the old foam, then spray glue the board and install the new material to the glued board. If so the material is sold by the yard at many cloth shops and online.If so you will need about 2&1/2 yards of material in the correct color. Get you some 3M spray glue just made for headliners. Probably take 2 cans,that's a big car.
Good luck ,Larry
Rocketowner is offline
Old July 29th, 2017, 07:02 AM
Good luck ,Larry
Correct. Unfortunately, the one-piece headliner board only fits through the windshield opening, so the glass needs to come out first. Bending it to force it through a door will not end well.
joe_padavano is offline
Old July 29th, 2017, 04:48 PM
It can be removed through the passenger door ,but you must work it underneath the steering wheel. We had a guy that came by our car lot every Thursday and reupholstered them in our shop for several years , and he never removed a windshield. I'm not saying that I could do it without damage to the board, but he could. Larry
Old July 29th, 2017, 04:58 PM
Olds Fever
CRUZN 66's Avatar
I have removed them through the passenger door... But I did remove the front seat as well...
CRUZN 66 is offline
Old July 29th, 2017, 05:00 PM
On a 2dr or a 4dr? I need to redo the headliner in my wife's 85 D88 4dr and I don't think it's coming out the passenger door, front or back.
Old July 29th, 2017, 06:05 PM
Olds Fever
CRUZN 66's Avatar
I was referring to a 2-DR... I thought the OP's 88 was a 2-DR, but looking closer at his photo that's not the case... I guess a four door might be a tight squeeze, never tried it... I would definitely be doing a lot of measuring and calculating before I removed the windshield, but better yet, I would just ask my local Upholstery Shop I have done business with in the past and get his professional advice...
CRUZN 66 is offline
Old July 29th, 2017, 06:52 PM
It actually isn't that difficult to pull the windshield. I've got the trim removal tool and the cutter tool for the urethane.
Old July 29th, 2017, 08:51 PM
Thanks for all the info. Yes mine is a 4-door. Looks like I'll be consulting a local upholstery shop about the headliner.
Old July 30th, 2017, 05:14 AM
This guy I am referring to did nothing else but replace headliners 6 days a week. He stocked material of all colors in his pickup, and he lived 75 miles from my place but came every week.
He has come into my shop at at 2PM ,do three headliners and we closed at 6PM.Full sized 4 Door cars were a big part of our sales ,so I'm sure he did those. There's a knack to doing some things ,and that must have been his. Larry
Old July 30th, 2017, 05:02 PM
Olds Fever
CRUZN 66's Avatar
That's true... I also have the tooling to remove windshields... BUT, there is that slight concern of chipping or cracking the glass... Remember good old Murphy...
CRUZN 66 is offline
1969camaross350
January 12th, 2015 05:23 PM
Monza900
June 19th, 2009 07:50 PM
Monza900
May 7th, 2008 05:19 PM
J-(Chicago)
February 8th, 2008 05:14 PM
J-(Chicago)
July 27th, 2007 01:50 PM
Quick Reply: Headliner for 1980-85 Delta 88
