bolts to remove steering wheel
Old Mar 27, 2017 | 01:00 AM
Haidda's Avatar
Hi,
i´m trying to remove the steering wheel from my 66 f85. I grew up with the metric system and loosing my mind right now. I tried UNF and UNC bolts to remove the steering wheel from the column - but none of them fits???
Any suggestions on that?
Thank you and BR
Daniel
Old Mar 27, 2017 | 07:11 AM
TripDeuces's Avatar
SAE is what you want. The size is probably a 5/16x18 or 5/16x24, coarse or fine thread. 18 and 24 are the number of threads per inch with the larger number being referred to as fine thread and the smaller as coarse. 5/16 is the bolt diameter which is once again in inches, 5/16ths of an inch. Youtube has videos on pulling steering wheels
Old Mar 27, 2017 | 08:00 AM
CRUZN 66's Avatar
Olds Fever
If you purchase an English steering wheel puller kit, it will most likely have everything you need to pull the wheel...
https://www.summitracing.com/parts/o...FYaIswodSAUDyw
Old Mar 27, 2017 | 08:30 AM
FYI, those ARE UNC and UNF, respectively.
Every wheel puller kit I've ever gotten has had an assortment of bolts in both English and metric threads. (Admittedly, the last time I bought a steering wheel puller, GM still used English fasteners in it's cars...) I'm pretty sure the Olds wheel is UNC.
nolabigdawg
Oct 25, 2014 11:50 AM
cameron_zank
Ninety-Eight
Oct 21, 2014 06:29 PM
elwood565
Apr 21, 2014 09:34 PM
KRICHEN922
Jul 1, 2010 09:17 AM
STRETCH1
Body work
Feb 17, 2010 06:09 AM
