67 Cutlass passenger window
My 1967 Cutlass supreme passenger window is only going down about 2 inches before it stops. It feels like it's getting stuck or binding on something. But I haven't been able to see where anything is getting caught. Any thoughts or insights would be greatly appreciated?
You will need to pull the door panel. There is a vertical rail that is also the vent window assembly vertical rail. It could have the guide weatherstrip bound up or coming apart and stopping you. There is a rear vertical guide as well and it could be causing that same issue. Both or those have a small amount of adjustment forward and back as well as in and out. I suspect it is the weatherstrip.
There is a lower stop at the center of the door towards the bottom but it only has about a quarter of an inch of adjustment so highly unlikely it is the issue.
bigdooly
December 17th, 2015 06:03 PM
Olds57rocketgal
November 22nd, 2007 10:02 PM
