67 Cutlass passenger window
Old Dec 17, 2016 | 03:28 PM
Rlasley's Avatar
My 1967 Cutlass supreme passenger window is only going down about 2 inches before it stops. It feels like it's getting stuck or binding on something. But I haven't been able to see where anything is getting caught. Any thoughts or insights would be greatly appreciated?
Old Dec 18, 2016 | 08:17 AM
lemoldsnut's Avatar
You will need to pull the door panel. There is a vertical rail that is also the vent window assembly vertical rail. It could have the guide weatherstrip bound up or coming apart and stopping you. There is a rear vertical guide as well and it could be causing that same issue. Both or those have a small amount of adjustment forward and back as well as in and out. I suspect it is the weatherstrip.
There is a lower stop at the center of the door towards the bottom but it only has about a quarter of an inch of adjustment so highly unlikely it is the issue.
Old Dec 18, 2016 | 03:27 PM
Rlasley's Avatar
Thanks! That was it. It was the rear vertical rail that had felt build up.
Thanks again
Rod
bigdooly
Dec 17, 2015 06:03 PM
69442
Aug 11, 2012 07:40 AM
Benny
Mar 8, 2011 08:53 AM
Vyse
Apr 15, 2010 10:57 PM
Olds57rocketgal
Nov 22, 2007 10:02 PM
