1966 cutlass upper steering column bearing or bearing kit not tilt
Old October 10th, 2016, 04:36 PM
sortasane's Avatar
I am having trouble finding the upper steering column bearing or bearing set for a 1966 Cutlass convertible non tilt column. Could you help.
sortasane is offline
Old October 10th, 2016, 06:56 PM
66-3X2 442's Avatar
The bearing is made into the turn signal and I haven't heard of a replacement being available separately.
66-3X2 442 is offline
Old October 15th, 2017, 04:06 PM
vickycar's Avatar
66 cutlass steering bearing
had same problem with my 67 442. googled parts number came up 66-69 gm mide size car chevelle ,Camaro with same part number. mine was non tilt floor shift. I would believe auto on column would be same as other gm.s with column shift. used same parts on many a gm app
vickycar is offline
Old November 16th, 2017, 01:42 PM
Ben
RAMBOW's Avatar
I bought mine from fusick's.
As mentioned above, it was part of the turnsignal switch assembly, and not a separate part.
RAMBOW is offline
Old November 16th, 2017, 02:06 PM
Fusick has probably the best price for one:
http://www.fusickautomotiveproducts....p?number=D6203
oldcutlass is offline
Old September 7th, 2020, 01:38 PM
RandyS's Avatar
In doing research on this subject, (looking for one myself) I found conflicting info. It appears that there are 2 styles of this assembly, one with a plastic mount, and with an aluminum mount, like the one I just removed. The seller on eBay that has the aluminum one for sale says that the 2 are not interchangeable, that if yours is currently the aluminum base model, you need to replace it with that style. Of course, that style is more expensive. Anyone have the scoop on this?
RandyS is offline
Old September 8th, 2020, 07:30 AM
RandyS's Avatar
Anyone?
RandyS is offline
Old September 8th, 2020, 08:04 AM
66SportCoupe's Avatar
2 styles
Yes that is correct. The two do not interchange.
66SportCoupe is offline
Old September 8th, 2020, 08:17 AM
RandyS's Avatar
Thank You!
RandyS is offline
starfire
December 9th, 2021 08:21 PM
KenOlds442
February 19th, 2016 04:49 PM
62 Olds
March 24th, 2015 06:51 PM
317Cutty
June 18th, 2014 10:53 AM
67442nut
December 26th, 2010 11:07 PM
Quick Reply: 1966 cutlass upper steering column bearing or bearing kit not tilt
