57 Carpet
Old Mar 28, 2016 | 05:45 PM
Pat McClelland's Avatar
57 Carpet
My 57 98 2dr ht is pink with charcoal interior. The trim code is 331. Where can I get the correct carpet? Thanks for your help.
Pat
ps. Would you put Dynamat under it?
Old Mar 29, 2016 | 06:05 AM
Rocketowner's Avatar
Pat, I found a company that list carpet for a 1957 Olds "98". It's Quality Car Interior. They show a Charcoal color available,but I didn't find anything by the color code "301". They state that they make them in "custom Colors", and also list insulation to go under the carpet.Give them a call and I bet they can tell you what will match or send you samples.
(556-256-6825). Tustin Ca. Good luck, Larry
Old Mar 29, 2016 | 08:27 AM
Tedd Thompson's Avatar
I used these guys a couple months ago on my 55 and had good fit and as easy install as I expected. You might give them a call.... Tedd http://originalauto.com/products/carpet-sets/
Old Mar 29, 2016 | 05:35 PM
Thanks for the help guys. My trim code is "331" not "301". Thanks again.
Pat
Old Sep 13, 2016 | 12:07 PM
TheDon's Avatar
When I had my '57 98 StarFire Coupe I looked high and low for over 25 years for the correct carpet. I have only seen two cars with the original correct carpet. The correct carpet has like a tighter weave diamond shape staggered about every 2" the same color as the rest of the carpet.
Good luck on your search!
Old Sep 14, 2016 | 07:34 PM
Dear Don, thank you for your response. I would love to have the right carpet, but my car has set too long. I have to get some carpet and seats right away. What can you suggest? It is pink with charcoal interior. I appreciate your help. Pat
Old Sep 15, 2016 | 08:09 AM
TheDon's Avatar
You might want check out all the contacts in a current Hemmings.
You will have to settle on deciding between the close cut weave "Daytona" or a standard Loop Cut Pile.
LeBaron Bonney Interiors (800) 221-5408
Originality Plus ( Might steer you in a direction)
10005 Lilac Road
Oak Hills, CA 92344
Phone: (760) 792-1020
Bill Hirsch (800) 828-2061
Old Sep 16, 2016 | 01:54 PM
Carpet
Would you choose the Daytona or the standard Cut Loop pile?
Old Sep 17, 2016 | 07:33 AM
TheDon's Avatar
The Daytona looks sharp and easier to vacuum, but just does not look right in the '57. The closer to the original I believe is the Loop Pile.
Get the supplier(s) to send you samples if they can.
Old Sep 18, 2016 | 07:19 PM
I saw an original 57 88 today at the Ottawa, Ks car show. It had loop carpet. The owner who also does interior work said it was closest to 80/20 Raylon loop. He said he prefers the Daytona but it looks a little sparse for a 98. The "plush cut pile" looks nice too. Would the 98 have had cut pile while the 88 appeared uncut? Any opinions are appreciated.
Pat
Old Sep 18, 2016 | 09:10 PM
harwooddan's Avatar
Try ACC carpet in Alabama they make the majority of original replacement carpeting but for my 55 Olds which is a Daytona weave the best price was Automotive Interiors in Massachusetts
Old Sep 19, 2016 | 09:21 AM
Thank you Hardwooddan. Is the Oldsmobile an 88 or 98?
Old Sep 19, 2016 | 11:20 AM
supmarjo's Avatar
hi, i just ordered this from e bay:
1957 Oldsmobile Golden Rocket 88 2 Door Post Carpet Loop 08 Dark Green... 80/20 Loop.....from:
Anniston, Alabama,
ill be a few weeks before install,but will post when i receive it, for quality n color match ...
Old Sep 19, 2016 | 03:20 PM
Thanks Supmarjo. Will you use Dynamat and then Jute under it?
Pat
Old Sep 19, 2016 | 08:22 PM
harwooddan's Avatar
My car is a super 88. I used dynamat in the trunk and interior floors as the carpet sample only had a foam rubber back. Then the carpet arrives and had the jute backing. I could have saved $200 bucks but still glad I did the trunk floor and the car is quieter. Hope this helps !
Old Sep 20, 2016 | 06:36 AM
supmarjo's Avatar
my car had spay under coating ( on the inside) but ill put something els also...not sure,been looking at you tube for info...... ill check back soon
Old Oct 26, 2017 | 01:52 PM
supmarjo's Avatar
..ok got the carpet installed fits good, had to cut out for the brake...you big issue.
did not add any more sound protection...carpet came w insulation.
nice carpet
milesmonte
Mar 23, 2015 07:31 AM
eightyeight394
Aug 29, 2007 11:22 AM
Devon76
May 25, 2007 12:29 AM
68Toro71442
Jan 20, 2007 03:45 PM
