64-65 Cutlass back seat dimensions
Old Mar 19, 2016 | 01:44 PM
6T8's Avatar
6T8
Hello, I was wondering if someone could give me the dimensions for the back seat of 64-65 Cutlass ? Coupe and convertible, I have a nice back seat and trying to figure out what it fits. Thank You.
Old Mar 19, 2016 | 02:19 PM
lemoldsnut's Avatar
If I understand correctly there is three different ones. F85 has no lower arm rests so it is a wider seat. Than what is in a Cutlass hardtop or convertible. And a convertible has wider arm rests and bases due to the top cylinders being there. So it has an even narrower seat.
I have a F85 i will take a measurement for you.
Larry
Old Mar 19, 2016 | 04:22 PM
6T8's Avatar
6T8
Thanks. I have a seat that measures 53" ish on the bottom cushion and 51" ish on the back cushion that came with some buckets I purchased. They have been redone in a " custom " material so I can't tell from the factory pattern. I know they don't fit GTO OR CHEVELLE because of the type of arm rest.
Old Mar 21, 2016 | 05:21 PM
6T8's Avatar
6T8
Can anyone help? Thanks
Old Mar 21, 2016 | 05:27 PM
lemoldsnut's Avatar
The only 65 I have is a 65 F85 2 door post car. So, those do not have a set of lower arm rests only a small arm rest about mid panel. So, the seat in those cars is wider like in a Chevelle. I have not take the bottom out yet but the seat back is 57" wide.
I suspect yours is from a car with Cutlass level trim that will have the lower arm rests. Those also have a filler on the upper section. A convertible seat is even narrower.
Hope this helps
Larry
Old Mar 27, 2016 | 01:00 PM
snapshot's Avatar
My 64 cutlass conv rear seat measures back top portion 45" lower 48"
bottom section front and rear is 48"
CanadianCutlass
Nov 18, 2014 03:55 PM
mat1227
Sep 13, 2013 04:52 PM
e129745
Suspension & Handling
Jul 18, 2013 02:48 AM
tmaleck
Jun 11, 2013 12:01 PM
hunter
Wheels and Tires
Apr 16, 2012 06:17 PM
