Winter is coming and no heat
Old Oct 8, 2015 | 10:57 AM
wyocutlass's Avatar
68 supreme w/ac, The blower turns on and blows air but the heater does not kick on. I have done some research and I am trying to figure out if the heater valve is bad?, or if the heater core isnt getting anything in there, or a vaccum line. For the most part what is the main issue for the car not blowing out hot air?
Old Oct 8, 2015 | 11:23 AM
Heater valve broken, blocked, or not receiving right vacuum signal is the most likely.
I do not recall whether vacuum opened or closed the valve in your year, so you'll have to check your CSM.
After that, make sure the right vacuum is being applied.
After that, make sure that the valve is opening.
Old Oct 8, 2015 | 12:25 PM
CutlassDad's Avatar
Thermostat?
Old Oct 8, 2015 | 12:26 PM
rocketraider's Avatar
Oldsdruid
Check:
1) coolant level, then check antifreeze concentration. You need at least 50/50 mix of antifreeze and water, both for freeze protection and proper cooling and heater operation.
2) if those are good, feel heater hoses. The one from back of intake to core should be HOT and core to water pump a little cooler. If block to core isn't hot, either the hot water valve is not working as Eric said, or there is some flow restriction in the heater core itself.
3) No vacuum hose is above suspicion. Make sure the storage tank to manifold vacuum line is intact and also storage tank to HVAC control (where it disappears into firewall).
4) Remote possibility of a bad selector or heater control valve on the HVAC head, after 45+ years. They were made of potmetal in those years and may have warped enough where the internal ports don't align.
Good luck.
Old Oct 9, 2015 | 10:16 AM
wyocutlass's Avatar
Check:
Good luck.
The thermostat is brand new. Installed one few months ago. Radiator is also fresh with a new flush and new coolant. I did feel the hoses and one was hot and the other not so much. It was more on the cooler side. I am thinking my problem is there. Either a core or the valve. Is there a way to check the valve before going and buying a new one?
Old Oct 9, 2015 | 11:27 AM
Drain the antifreeze, take the hose off and see if you can spray water through it, in one direction or the other, with the vacuum in the correct state.
While you're at it, make sure water blows through the heater core properly.
Old Oct 11, 2015 | 07:45 AM
wyocutlass's Avatar
I figured it out! Thanks everyone for the help. I had a missing vacuum hose. The heater blows great now. Thank you.
Old Oct 11, 2015 | 08:24 AM
In most cases its always the simple things.
Old Oct 13, 2015 | 01:01 PM
Well, 50/50 may be optimal for most situations but it certainly is not mandatory for anything other than freeze protection down to -34ºF.
Straight water (or any concentration of antifreeze/water) will still heat up to thermostat temp and give hot air out the heater, and it will also cool the engine adequately (actually a lower concentration of antifreeze has a higher heat capacity so it absorbs and transmits heat better). What a 50/50 mix does is reduce the freezing point by 66ºF, prevent corrosion, and increase the boiling point by ~15ºF.
I run 30% antifreeze in my car as that gives freeze protection to ~0ºF and our winter temps rarely ever get into the 20s, so no worries there; the higher water concentration provides more cooling capability during the summer; and the 30% gives me corrosion inhibitors.
But yeah, 50/50 mix is easy to do and gives good all around protection.
Old Oct 13, 2015 | 04:00 PM
Octania's Avatar
That's some good scientific info right there
thanks for summarizing it.
shamusj
Dec 24, 2017 03:13 PM
Dream Whip
Aug 9, 2016 02:59 PM
84oldsDelta88
20
Jan 12, 2016 01:36 PM
smcurro
Paint
Jan 29, 2012 02:31 PM
bjtstarfire
Nov 13, 2008 02:04 PM
