Windshield wiper control
Lance - Are you referring to the chrome faceplate/bezel OR the wiper switch itself.
Faceplate is held on with two VERY SMALL stamped speed nuts....who knows what size those are...probably need a microscope to figure that out!
Switch is held on with 3 #8 x 1/2" hex flange screws (1/4" socket size for the head)
If you need some let me know.
The stamped speed nuts are also 1/4" socket size....if the bezel mounting studs are stripped a bit then just pry/pull against the bezel from the frontside while turning the socket on the nuts.
2blu442
January 3rd, 2010 05:28 PM
