what olds is this steeringwheel from?
It probably does. It's not hard to pop your wheel off and see if the new one fits - you already bought it, so there's nothing to lose.
You will need a steering wheel puller (or similar two-screw flat puller) though.
Still waiting to receive it in the mail,forgot to write it on the top, now i have a grant gt steering wheel so its not hard to get out since i have it out some thimes before, i Will try when i receive it for sure its a little rusty around the splines so i need to clean it and lube it up first before install or maybe it will get stuck, thinking to use some grease too
