what olds is this steeringwheel from?
Old Jan 30, 2015 | 02:55 PM
Oldsragger's Avatar
Like the topic, does any know? Just bought it used, think that would fit my car...
Old Jan 30, 2015 | 03:32 PM
65JS1's Avatar
That's out of a late 70's early 80's Cutlass. Don't know for sure how many years it was used for. Or if it was available in other models. But I had a 79 with the same one.
Old Jan 30, 2015 | 03:46 PM
Oldsragger's Avatar
Aha, thanks, but i hope it have the same mounting splines so i can possible use it..
Old Jan 30, 2015 | 03:53 PM
It probably does. It's not hard to pop your wheel off and see if the new one fits - you already bought it, so there's nothing to lose.
You will need a steering wheel puller (or similar two-screw flat puller) though.
Old Jan 30, 2015 | 03:57 PM
Oldsragger's Avatar
Still waiting to receive it in the mail,forgot to write it on the top, now i have a grant gt steering wheel so its not hard to get out since i have it out some thimes before, i Will try when i receive it for sure its a little rusty around the splines so i need to clean it and lube it up first before install or maybe it will get stuck, thinking to use some grease too
Old Jan 31, 2015 | 11:32 AM
It does. Steering wheels interchange from 1969-up with no issues.
jwavanlaarhoven
Nov 6, 2009 04:30 PM
Oldsmofjord
Jan 9, 2008 04:01 PM
