Under dash heat/ac parts?
[I]Your car must have been the early build. The parts circled in blue are the first design but at some point they switched to a fabric flexible duct going to the passenger side as well as the driver side. In my experience this plastic L-shaped tube is pretty hard to find. So it looks like you are missing 4,5, 7,8, 14, & 15. I have 14 & 15 if you need them.
I can't tell for sure but it looks like you might be missing the actual movable vents in the top center dash piece & both sides? I probably have those also.
This hoes is the only piece I have for you. It is an aftermarket piece but is very flexible and is long enough you could cut it to the proper length for your defroster hoses. Give me a call if you want? 317-727-7041.
69442murph
June 27th, 2020 07:12 PM
smcurro
Paint
January 29th, 2012 02:31 PM
