Sticky door latch?
Old May 13th, 2018, 10:19 PM
csouth's Avatar
Sticky door latch?
On my 72 Cutlass, I replaced some really crappy door handle mechanisms on both sides as there was a lot of play in splined portion. The passenger side door opens freely from the inside, but you have to literally yank on the inner handle to open the door. When the handle is pressed from the outside the door opens immediately. I'm assuming the door latch should be next? If so, is there one vendor over another that has a better quality part?
csouth is offline
Old May 13th, 2018, 10:45 PM
It could be the linkage is bent/stretched. I think the latch operates the same whether it is activated by the interior handle or the exterior handle, so the difference in operation could be due to the linkage rods.
Fun71 is offline
Old May 14th, 2018, 12:32 PM
csouth's Avatar
Thanks, I'll pull the latch out when I get home to see if it looks bent.
csouth is offline
yeahbuddy
September 9th, 2010 03:24 PM
jensenracing77
February 23rd, 2009 05:52 PM
scrappie
April 1st, 2008 08:28 AM
bandit600
November 15th, 2006 06:24 AM
Quick Reply: Sticky door latch?
