Steering wheel installation
Most steering wheel center caps just pull off.....some horn button assemblys are screwed with screw holes on the back side of the wheel....You need a steering wheel puller to do the job easily....the repalacement wheel will push on and then the center nut goes on tight. The one there now needs the puller....make sure the wheels are straight when you put the new wheel on straight.
