Steering wheel installation
Old Apr 10, 2008 | 01:51 PM
1968 42's Avatar
Want to swap out a grant wheel with an authentic 16" "wood" wheel. Can someone help me with assembly tips (e.g., how I remove the horn cap w/o distroying it, etc.). Tks.
Old Apr 10, 2008 | 02:20 PM
Oldsmaniac's Avatar
Most steering wheel center caps just pull off.....some horn button assemblys are screwed with screw holes on the back side of the wheel....You need a steering wheel puller to do the job easily....the repalacement wheel will push on and then the center nut goes on tight. The one there now needs the puller....make sure the wheels are straight when you put the new wheel on straight.
Old Apr 11, 2008 | 09:30 AM
Run to Rund's Avatar
Factory wheels have a mark that lines up with a mark on the end of the column, like a chisel notch.
Keegan
Mar 6, 2014 07:14 AM
bulldog
Apr 12, 2011 06:18 AM
#1CutlassSupreme
Jun 5, 2009 09:22 AM
GothamCity
Aug 5, 2007 06:29 PM
Chris L.
May 28, 2004 09:44 AM
