Starfire center console removal
Started taking the interior out of the starfire last night, for info purposes its a 64 btw. Anyway, the seats removed easily, but im stuck on the center console, im at work and didnt take pictures last night but I'll try to explain the best I can. Ive gotten the tach and top plate off, ive removed both plastic trim pieces that run the length of the console, console door removed. Basically im down the bare carpeted console. I found a phillips head screw underneath the courtesy light on the right side lf the console, but as far as i can tell there isnt a screw on the left side in the same location. Im just curious what im doing wrong or how the console mounts to the floor or tunnel. Thanks guys.
Cody
Cody
OK, make it easy on yourself. First go to:
www.wildaboutcarsonline.com and sign up. It's free.
Once you've signed up go to:
http://wildaboutcarsonline.com/membe...ctions_12A.pdf
and go to page 12-10. All will be revealed to you.
srbz
April 4th, 2015 11:36 AM
