Seatback removal
Seatback removal
OK, this is probably easy but how do I remove the plastic seatbacks on 72 cutlass bucket seats. I have the screws off the bottom of the seatback but I am not sure how to remove the latch or if the latch needs to be removed at all. I am being pretty careful because they are in good shape and I don't want to break them but mice made a home in the seats and boy do they smell!!! So I am trying to get the foam and trim off the seats.
Actually, I don't think the mice used the seat as a home the entire car was their home and the passenger seat was, apparently, the bathroom.
Almost all older GM rear seats remove the same way.
Remove lower back seat bolts (2)
Then grab the bottom and pull it about ~6" and push it UP and wiggle each side one at a time.
It will wiggle off the brackets it's leaning on. There should be one L, R, and Middle.
Bench seat back removal
Richey
70 ctls
December 8th, 2012 11:33 PM
