Restoring convertible top mechanism
Old Mar 9, 2019 | 06:14 AM
cdrod's Avatar
Rodney
Hey fellow ClassicOldsmobilers. What is the best way to restore a rusty convertible top mechanism? I finally got mine to move after several liberal applications of PB Blaster. It moves freely now but has a lot of surface rust that I would like to remove before paint. I talked with my powder-coater here in Houston about blasting and powder coating it as a complete assembly, but he thought the powder would be too thick and limit motion.
Can I disassemble it to strip & paint the individual components? It looks like some pivot points are riveted together (not bolted) so disassembly may not be an option for me.
It's a very complicated mechanism and I'm concerned I will screw up the alignment of all the moving parts when I reassemble after paint.
I would love some advice from someone who has already done this. Thanks!
Rodney
Old Mar 9, 2019 | 07:48 AM
Yes, you can partially disassemble it, clean, paint, then reassemble. I did this back in around 2004 and it was a very straight-forward process. I didn't disassemble very pivot as you can see below, but I was still able to paint the frame and it still looks good today.
Old Mar 9, 2019 | 12:45 PM
scrappie's Avatar
I have some OEM top latches available if that helps?
Old Mar 9, 2019 | 05:03 PM
cdrod's Avatar
Rodney
Kenneth:
Thanks for the comments and pictures. Was it difficult to reassemble and align properly after painting? Did you make witness marks to get everything back adjusted back to the same locations?
Old Mar 9, 2019 | 11:06 PM
The parts went back together in correct alignment as the only disassembly was bolt/nut removal and as such reassembly was just replacing the bolt/nut. There was one joint that didn't have the original dual stepped shoulder bolt and someone had used a machine screw/nut in its place, so I had to make a replacement at the machine shop at work, but I have since seen those are available at the resto houses. Anyway, it was essentially take apart, paint, then put back together. No real issues, so go for it.
This is the aftermarket pivot bolt that I had to make as they weren't available back then. Seems kinda odd as what I machined seemed a bit simpler. Whatever, if you don't have access to a Bridgeport milling machine then this is a great replacement part.
Old Mar 10, 2019 | 01:39 AM
cdrod's Avatar
Rodney
Kenneth:
Thanks for the advice!
Scrappie:
I have an extra set of latches in case some of the originals are too rusty to be reused.
chip-powell
Apr 2, 2019 11:53 AM
acavagnaro
Paint
15
Jul 20, 2015 08:30 PM
kbdecatur
Jun 12, 2012 05:06 AM
bonezarally
Jul 12, 2011 08:47 AM
denis
Feb 16, 2007 12:20 AM
