Removing tint film from windows
Old Feb 28, 2016 | 08:17 PM
mac-n-me's Avatar
Smile Removing tint film from windows
The '72 Cutlass we just got has window tinting film on all but the windshield. Its peeling in places, and leaving an adhesive residue behind.
I looked at a lot of different suggestions for removing both the film & residue. The one found at the link below, involving a clothes iron & pocket knife, is the quickest & most effective of the suggestions I viewed. I just thought I'd share the link because most of the methods seemed much more complicated than they need to be.
Old Feb 28, 2016 | 08:19 PM
A-body glass is ubiquitous.
Easiest just to replace it, and sell the tinted glass to another victim.
Old Feb 28, 2016 | 08:55 PM
mac-n-me's Avatar
"victim" is about right, lol
Old Feb 28, 2016 | 09:22 PM
I hate that stuff
Old Feb 29, 2016 | 08:20 AM
RROLDSX's Avatar
How to remove tints with an iron (SUPER EASY)!!!! - YouTube
Not sure it would work on window tint glue but I recently discovered the best thing to remove glue (other than laquer thinner) is....... None other than WD40 with a micro towel. It works better than Goo Gone (basically laquer thinner) or any other glue remover I've found. The glue needs to be warm like in the hot sun warm.
Old Feb 29, 2016 | 04:24 PM
mac-n-me's Avatar
Thanks, because I didn't get the result the people in the video got. My film comes off no problem, but the adhesive stays. My iron wasn't steaming well in the upright position you need it in to steam the windows
Old Feb 29, 2016 | 04:44 PM
Once the film is off, the adhesive should be easy - something will dissolve it.
Try whatever is at hand first. After that branch out.
Most likely solvents are lacquer thinner, mineral spirits, WD-40, denatured alcohol, acetone, and xylol (all available at your local hardware store or Home Despot).
If none of those dissolve it, then it;s from outer space.
The good news is that none of those dissolve glass, so you're completely safe using them all (the only thing that will dissolve glass is hydrofluoric acid, which I don't recommend getting within ten yards of).
Old Feb 29, 2016 | 08:19 PM
mac-n-me's Avatar
Thanks, and I'll be sure to avoid the hydrofluoric acid, lol.
Old Feb 29, 2016 | 08:23 PM
Actually ammonia and fine steel wool works.
Old Feb 29, 2016 | 08:39 PM
Ammonia. Forgot about that one. Brilliant stuff.
Use full strength, outdoors. Wear gloves. Don't inhale or get it in your eyes.
Old Mar 1, 2016 | 05:33 AM
cherokeepeople's Avatar
go get some 3M adhesive remover.if it's an adhesive it will break it loose and won't hurt painted surfaces.
Old Mar 1, 2016 | 12:23 PM
1968_Post's Avatar
I had to remove the tint from my 442. It was not an easy process. I tried 3M release agent, ammonia, and every other thing I could think of. What ended up working the best for me was WD40, a razor blade and super fine steel wool. Work small areas (like 6"x6") and then move on. I tried to do larger areas but the adhesive turned to gum and was a pain to remove.
I'm glad I only had to do this once. It was a royal PITA!
Old Mar 1, 2016 | 02:59 PM
I had a similar experience with a car back in the 90s. The film peeled off fairly easily but left the glue behind. I used isopropyl alcohol and a safety razor blade to remove the glue in small sections.
Old Mar 6, 2016 | 03:06 PM
mac-n-me's Avatar
I tried to buy a scraping razor at our mechanics shop to remove the adhesive. He said I didn't need one, to use soapy water in a spray bottle, then scrape window with the edge of a credit card. What do you know, it worked. So simple. I'd imagined this little project to be a major pain. Shows what I know
Old Mar 6, 2016 | 03:09 PM
Great trick! Thanks!
Old Mar 7, 2016 | 12:10 PM
BackInTheGame's Avatar
Maybe it was a different adhesive that held mine on, but I found that on a warm day in the sun, keeping the tint wet by application of Windex/ammonia-wetted newspaper, re-wetted frequently, and left to itself for about 90 minutes allowed the film to peel right off, taking nearly all of the adhesive with it. For the very few spots of adhesive left behind, more wetting/waiting did the trick.
YMMV - Good Luck!
Ficks
Jan 11, 2016 07:42 PM
tailfins
Sep 18, 2013 12:34 PM
italian ice
Oct 5, 2010 01:06 AM
gearheads78
Jan 27, 2009 01:09 PM
Gert3116
Jul 18, 2008 04:46 PM
