Rear window keeps popping off it's ...connection points
Old Aug 21, 2024 | 05:05 PM
jpilk99's Avatar
Hi. Not sure if this is the correct sub-section for a window question but...
I have a '72 98 and the drivers' rear window has popped off it's regulator/rails/lower plastic round connection a few times. Thinking I need a new ...white plastic 1" round connection point for the bottom "nipple" of the glass. Wondering if anyone else has had this happen, or purchased a new white plastic disc to solve the problem. (See pics).
Thank you. Hope that made sense.
Jay
Old Aug 22, 2024 | 04:59 AM
Oldsguy's Avatar
Past Administrator
Is it possible that the metal regulator that the nylon "washer" rides in has been bent a little or is maladjusted? It looks like the lower end of the regulator can be moved by loosening the bolt on the bottom and moving it a little one direction or the other. Replacing the nylon part would not hurt but may not be necessary.
Old Aug 22, 2024 | 06:36 AM
jpilk99's Avatar
I'll check that out. Thank you
Phoenix8990
Jul 23, 2021 04:14 PM
JOHNNYOLDS442
Jun 22, 2020 06:28 AM
71OldsCool
May 18, 2014 07:07 AM
toms1966rgtop
Mar 9, 2010 02:09 PM
69442
Dec 2, 2009 06:55 AM
