Rear view mirror dilema
Old Mar 18, 2015 | 12:49 PM
RROLDSX's Avatar
I am about to get my windshield installed and I noticed the area behind the mirror base is exposed. I had my headliner installed so I don't recall how this is covered from being seen through the windshield. The stainless trim is too thin to possible cover the and I can't find anything in the manual that refers to this.
Randy
Old Mar 18, 2015 | 01:40 PM
oldspackrat's Avatar
it looks like the cover might be a little askew at the very front? Maybe tuck that gray wire in a little bit and make sure the little tabs on the metal part are in the correct spot in the cover. Otherwise the cover and that thin piece of windlace is correct.
Old Mar 18, 2015 | 01:55 PM
RROLDSX's Avatar
Thanks Scott!
Old Mar 19, 2015 | 09:05 AM
^^^This, exactly. The soft plastic cover for the mirror base needs to be slid over those tabs on the leading edge of the bracket. That does not appear to be how it is installed in the photo. Usually you need to start with the cover further forward against the windshield, the push up while moving it rearward to engage the tabs. Then install the screw.
stevengerard
Dec 31, 2009 04:01 AM
roy341
Jul 11, 2009 05:27 PM
tim72
Apr 9, 2009 05:33 AM
64 Olds Dynamic 88
Apr 27, 2008 06:53 PM
<diablo76delta88>
Sep 11, 2003 08:41 PM
