Rear seat
Old May 12th, 2009, 03:21 PM
foo
foo's Avatar
Rear seat
Is there some sort of trick to make it easier to get the rear seat out on my 70 442?
foo is offline
Old May 12th, 2009, 03:43 PM
car guy
gearheads78's Avatar
There is a little bracket that the seat frame sits down in to on both sides of the lower front. Just push at the bottom front toward the back of the car and pull up to clear the bracket. Takes less than 2 seconds to get out the bottom part. The top is either fastened by two screws at the bottom or not I've seen it both ways. You then just pull straight up to release it at the back.
gearheads78 is offline
Old May 12th, 2009, 04:18 PM
Geezer
Texascarnut's Avatar
That's the way it should work, but I've ran into cars with the stupid bracket welded in off target a bit and it took more than a simple push backward to get the eye on the seat frame free. Sometimes a flat steel wrecking bar is needed to get enough leverage against the seat base. Makes one wonder how they ever got the thing in at the factory in the first place.
Texascarnut is offline
Old May 12th, 2009, 05:34 PM
Member
Doug69Cutlass's Avatar
Since you guys are all talking about taking the rear seats in and out I have a question too. I have the rear seat out of my 69 right now and just got the new rear door wind lace I was waiting for so I will be reinstalling the seats. I have read that you should put anti squeak on the seat wire brackets that fit into the brackets that hold the seats. Does anyone know what this is or use it?
Doug69Cutlass is offline
Old May 12th, 2009, 05:48 PM
car guy
I have never seen anyone use anything for that but felt would probably do what you want to do.
Old May 12th, 2009, 09:54 PM
Member
I guess since it didn't have anything on the brackets when I took it apart and it didn't squeak I decided I am not going to put anything on them.
Thanks,
Old May 13th, 2009, 02:39 AM
Yellowstatue's Avatar
Angry Secret screw
I have seen some backrests that have a philips screw on the 'trunk side' after fighting with it for ten minutes I go into the trunk (servants entrance) then have to figure out what I am dealing with then find out that they put a philips screw in the top horizontal bar under the parcel shelf... as for the seat bottom, try using a rubber mallet to strike the seat rearward to disengage the hook...
Yellowstatue is offline
Olds442redberet
January 14th, 2015 06:12 PM
mydadscutlass
July 16th, 2012 08:41 PM
68Tom
May 8th, 2012 07:41 PM
Nor Cal Andy
April 1st, 2011 07:13 PM
68Tom
September 16th, 2010 10:41 AM
Quick Reply: Rear seat
