Rear package tray replacement..
Old Feb 7, 2019 | 11:52 AM
72455's Avatar
1972 U code Supreme
On a 72 Supreme what's involved and what else would I need besides the tray itself? Checked the CSM and didn't find anything...
Thanks,
Dave
Old Feb 7, 2019 | 12:35 PM
AJFink's Avatar
Thanks,
Dave
What parts are you referring too? The cardboard/top finished or the metal components.
Old Feb 7, 2019 | 12:57 PM
That's because except for the dashboard, all the interior service items are covered in the Fisher Body Manual.
You'll need to remove the rear seatback to get to the glued strip at the leading edge of the package tray, and the seat bottom has to come out to get the seat back out. You'll also probably need to remove the garnish moldings around the sides of the package tray.
Old Feb 7, 2019 | 03:09 PM
72455's Avatar
1972 U code Supreme
Thanks Joe...I'll check the body manual. Are the garnish pieces available should I need them?
Old Feb 7, 2019 | 03:10 PM
72455's Avatar
1972 U code Supreme
The cardboard top and the mesh fabric.
Old Feb 7, 2019 | 04:25 PM
green1972's Avatar
the seat bottom has to come out, then the seat top, then both side panels, where the window cranks are, , and the rear corners package tray hold downs, and the if you have the side courtesy light you can just take the screws out and pull the side sail panel covers up , but you dont have to totally remove, slide the old one out, replace the underlayment , slide the new one in, use the 3m best glue for the front edge, tape the edge down and let the glue dry for a hour, remove the tape and go in reverse to put back together, a good 3 hour job, Tim
Legendary has the mesh and non mesh, my opinion the best quality
Old Feb 7, 2019 | 04:49 PM
JohnnyBs68S's Avatar
Or you can do something custom like this...……
My mom made this hook-loop carpet that I laid out for her in...…...1985. She was big into making the Skillcraft hook-loop carpets that came in kits popular in the '70s and '80. Probably cost a whole $30 in stuff available at Hobby Lobby. Sure it ain't stock, but I think looks pretty cool.
Old Feb 7, 2019 | 04:51 PM
Originally Posted by JohnnyBs68S
My mom made this hook-loop carpet that I laid out for her in...…...1985. Sure it ain't stock, but I think looks pretty cool.
Your Mom is cool. I like it.
Old Feb 7, 2019 | 05:01 PM
72455's Avatar
1972 U code Supreme
Here's one possibility...
https://www.yearone.com/Product/1964...s-442/pd372dgr
Old Feb 7, 2019 | 05:02 PM
72455's Avatar
1972 U code Supreme
... and another possibility...
https://www.opgi.com/cutlass/CSS58/
Old Feb 7, 2019 | 07:21 PM
72455's Avatar
1972 U code Supreme
Hey Joe where is it covered in the body manual? I checked the index and didn't see anything that referred to the package tray.
Old Feb 18, 2019 | 03:04 PM
72455's Avatar
1972 U code Supreme
What kind of glue?
Old Feb 18, 2019 | 04:26 PM
green1972's Avatar
3m 08090 spray both pieces , let it really tack up and put together, you can tape it from top to bottom , best for a couple hours and then reinstall everything, Tim
KDW
Jun 12, 2015 10:15 PM
KDW
Jun 10, 2015 01:25 PM
steverw
Dec 31, 2014 02:22 PM
Chumley
Feb 25, 2011 02:15 AM
mujram
Jul 9, 2010 10:26 AM
