Rear bench seat 1969 Cutlass
Old Aug 7, 2024 | 06:05 AM
ssbigken's Avatar
All right so I was getting my back seats reupholstered I have a 69 Cutlass supreme I pulled them out brought them to the shop and the frame winded up being rusted and pretty shot I believe they were 53 in wide I have a parts car that I pulled the rear seat out of took it up there but the frame was wider I believe 58 in will that drop in there with no interference on the rear door panels or do I need to find a whole new rear seat frame or butcher the two to make one thank you for any info you guys can provide
I got the wider seat to fit but I fill like I'm missing some trim here and if so will that interfere with the wider based seat i know my rear door panels will not cover that gap there maybe a half inch wide that is at least 3 inch gap or should I use the base and get custom with the trim piece thanks again
Old Aug 7, 2024 | 06:43 AM
66_Jetstar's Avatar
If you have a convertible then the rear seat is narrower and a hardtop seat will NOT fit. You'll need another convertible rear seat. Cores are getting harder to find and more expensive..
Tjohn8573
Apr 8, 2021 04:39 PM
71CutlassPost
Jun 19, 2020 08:30 PM
donfitzgerald
Nov 3, 2014 09:07 AM
Eaglesfan
Jun 29, 2014 07:12 AM
Olds442toro
May 29, 2014 07:58 PM
