Package tray area help
hey guys theres two pieces (one in each corner of the rear of the package tray) i was wondering if anyone knows the name of the part and where i can get them (aftermarket) or even ebay or whatever ... lol i just need a name so i can get this interior done please!!!! summer is here .... ill attach a pic of the package tray area and a shot of the corner thats empty (missing part area top left of picture )
Hi, I checked in my Body by Fisher 1968 Service Manual (compartment shelf trim). The long molding (between the missing pieces) is called the back window lower garnish molding. So I'm assuming your missing pieces are the L & R lower corner garnish moldings, the manual did not go into that detail. On my '68 I have similar moldings, they appear to be just extensions to tie the whole lower garnish together.
Hope that helps.
Don
Hope that helps.
Don
They're generically referred to as "Package Tray Corners" and/or "Eggshells".
I have good, unbroken, used originals of those "PACKAGE TRAY CORNERS"...right now only one side (P side) but could probably come up with a nice D side to match.
Or---run a "Parts Wanted" ad and you should be able to come up with a nice used set from someone on here.
Don't know on repros....you'd need to check with some of the repro places.
another question !!!
does anybody know what goes between these two eggshell corner pieces ( if anything does go betweeen them ) and also what color do i paint the eggshell corners ( color of the car or interior ) because as of right now the color of the surface that the backglass sits on is the body color ...
help!!!
sorry to bother guys
had another question regarding the two package tray corners (eggshell pieces)
i found the parts (thanks for helping)
but i was just wondering if anything goes between the two package tray corner pieces because as of right now all i have is the painted metal ? just doesn't look right
Tony
1971 cutlass 'S'
2 dr coupe
Tony
1971 cutlass 'S'
2 dr coupe
Tony
1971 cutlass 'S'
2 dr coupe
Tony
1971 cutlass 'S'
2 dr coupe
The two small corner pieces and the one long metal piece (built into the car) all should be painted satin/semi-flat black for GM's anti-glare purposses.
