Oopsies. 4 way power seat.
Old Apr 24, 2021 | 03:51 PM
Bandit60's Avatar
In the final stage of putting the 442 back together. Had the bucket seats out to clean up the seat rails and clean and lube all the moving parts. Disconnected and used graphite to lubricate the drive cables and during reassembly heard the dreaded crack of plastic breaking. You guessed it the sleeve that provides the resistance that holds the green cable connected to what I believe is the transmission broke rendering the seat disabled. Now finally the question. Will a speedometer shop be able to duplicate this cable or do I start an internet search to try and find a replacement? It was a great day until a 51 year old piece of plastic decided to rattle my cage. Dad gum it
Old Apr 24, 2021 | 04:42 PM
2blu442's Avatar
Are you needing the cable or just the sleeve? Can you share a picture of what broke?
Old Apr 24, 2021 | 05:11 PM
CRUZN 66's Avatar
Olds Fever
I am sure someone here will most likely have a drive cable... Post a photo of the cable and the length measurement...
Old Apr 24, 2021 | 06:36 PM
Bandit60's Avatar
10 inches long.
The lip is broken.
Old Apr 24, 2021 | 06:37 PM
Bandit60's Avatar
Not good with computers but I hope this is the info requested.
Thank you
Old Apr 24, 2021 | 06:57 PM
jensenracing77's Avatar
I have repaired these before using the easier to find long cables from a bench seat. You can get those ends off but you have to be careful. Just cut the old one off being careful to not cut the green part. Take one off the long cable and glue it to the green one, They will come off without cutting if you take your time and pick at the green center. I have also taken a long one and cut each end off so that it was the correct length overall and glued a center connector tube to them to hold them together. Either way, Both methods worked perfect. Just need to find a long one.
stringbander
Dec 17, 2018 06:26 AM
Alg
Nov 27, 2015 05:00 PM
spate51
Jan 2, 2014 03:15 AM
hajnovak
Jun 15, 2013 08:13 PM
lonestarjarhead
Mar 17, 2012 11:34 PM
