olds 98 interior questions
Old Sep 17, 2009 | 12:58 AM
Rick's Avatar
From: I live in Invercargill at the bottom of the South Island New Zealand.
Smile olds 98 interior questions
Hi Im new to this site and Im in New Zealand. I have recently imported a 1966 Olds 98 from Arizona and it needs a new horn ring. If any one can help it would be much appreciated. I also have a 1975 royale 88 convertible. Great cars but nothing available in NZ for them.
Old Sep 17, 2009 | 02:18 AM
jensenracing77's Avatar
what wheel do you have? i have one for one of the wheels but not sure which wheel is deluxe and what one is standard. i will post a picture when i get home from work. if you don't hear anything by tomorrow then give me a PM to remind me.
Old Sep 17, 2009 | 02:32 AM
Rick's Avatar
Smile olds horn ring
I have posted 2 pics of the ring.
Old Sep 17, 2009 | 03:43 AM
Welcome
Welcome aboard
Don't have your part but it's nice you joined us.
Old Sep 17, 2009 | 04:04 AM
66ninetyeightls's Avatar
Land Yacht Captain
welcome to a fellow 66 98 owner
Old Sep 17, 2009 | 04:58 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO Rick, hope you find your parts.
Old Sep 17, 2009 | 08:02 AM
citcapp's Avatar
Talking Welcome to CO
I give you guys lots of credit for buying these cars knowing parts are going to be tough to find and also pay the shipping costs to get them. Good luck in finding your parts
Old Sep 17, 2009 | 12:06 PM
Rick's Avatar
Thanks for the welcome guys Ill post some pics of my cars soon.
Old Sep 17, 2009 | 12:11 PM
i have the two spoke wheel. i don't know if the center piece is the same. i figure that they are differant.
100_3859.jpg?t=1253214552
Old Sep 17, 2009 | 12:52 PM
Rick's Avatar
If the column is telescopic and tilts the wheel will fit. It might be easier to change the lot. If nothing else turns up Ill probably do that. Ill keep in touch. Thanks.
Old Sep 17, 2009 | 01:57 PM
carmax's Avatar
Rick,
Did you get that car off of E-bay a few weeks ago?
Carmak
Riverside, Iowa
66 98 LS driver project
Old Sep 17, 2009 | 07:30 PM
Rick's Avatar
No Its been in NZ about 6 months.
Old Sep 18, 2009 | 09:35 AM
carmax's Avatar
Just curious. I saw a good project in AZ om E-bay recently.
I like the dark blue of your interior. What color is the car?
I have a friend with a 66 Toronado parts car. I'll see if he has the tilt-tele horn ring.
Carmak
Old Sep 18, 2009 | 01:24 PM
Rick's Avatar
The colour is light blue but sunburnt in places. the vinyl top is a bit lumpy and needs replaced but overall its in pretty good condition.Its on 14inch rims.
Old Sep 18, 2009 | 05:29 PM
bigoldscruiser's Avatar
2 '66 98's
Originally Posted by Rick
Its on 14inch rims.
Unfortunately, they all are! That makes it a challenge to get adequate tires.
The car looks great. I see it has A/C, T & T steering wheel with cornering lights. What other options does it have?
Bruce
Old Sep 18, 2009 | 10:12 PM
Rick's Avatar
Its got all the vanity fittings , pull out mirror on the back of the front seat with lots of interior lighting. Its has heavy duty rear air shocks and a tow hitch and electric fittings for trailer brakes. Ive just fitted a set of new chrome rims with 215/75x15s to my 75 88 so Ill fit the 225/75x15s and rims onto the 98. thatll give her a bit of a lift.
Old Sep 29, 2009 | 02:01 AM
Rick's Avatar
blinker switch
Does any one have an easy way to remove the blinker switch from my 66 olds 98? I have the wheel off but the switch will not fit thru the column tube. Does the whole column have to be removed? I would appreciate any suggestions.
Old Sep 29, 2009 | 05:43 AM
Land Yacht Captain
LOL I just did this on my 66 on Sunday. Its pretty easy. There are 3 Phillips screws that need to be removed & the switch will pull out along with the trim around it. There is a metal plate that the switch screws to that will need to be removed in order to pull the wiring out through the column.
Hope this helps.
Craig
Old Sep 29, 2009 | 11:18 AM
Rick's Avatar
Thanks Ill try that.
Old Sep 29, 2009 | 04:49 PM
Rick's Avatar
I still cant remove the outer tilt casing that houses the switch.
Old Sep 29, 2009 | 05:48 PM
Land Yacht Captain
Ahhh there's a problem. Mine doesn't have tilt & I don't know what that setup looks like.
Old Sep 29, 2009 | 05:59 PM
Land Yacht Captain
I just checked the Chassis manual to look at the instructions for that option. WOW thats a whole different monster to take apart.
I would recommend you get a chassis manual as it is more involved than the basic steering column,
Old Sep 29, 2009 | 06:08 PM
Rick's Avatar
Thanks Craig.
Old Sep 29, 2009 | 06:54 PM
2 '66 98's
Rick, Unless the cable is broken, don't try to take the upper part of the column apart. The switch is external at the bottom - operated by the cable running down the column. Look at your PM's. I sent you one a little while ago.
Bruce
Old Sep 29, 2009 | 08:42 PM
carmax's Avatar
I have had a couple of these tilt-tele columns apart. If I remember you unscrew the blinker stalk and unbolt the shifter. Use a wide flat chisel and slowly slide the upper column cover up and off.
The blinker mechanisim in these units is prone to failure and very hard to find.
It might be much easier to switch over to a non-tilt-tele column than to find these parts.
Good luck!
Carmak
Old Oct 4, 2009 | 12:01 PM
rane58's Avatar
Thumbs up
Welcome Rick, nice car..!
Old Oct 4, 2009 | 12:07 PM
Rick's Avatar
Thanks, Thats a nice car youve got also.
Old Oct 11, 2009 | 06:21 PM
Land Yacht Captain
Hey Rick would you mind posting pics of the VIN tag inside your drivers door jam. Feel free to blur out the numbers if it makes you feel more secure. Mine is missing & I want to see what the factory tag looked like.
Craig
Old Oct 11, 2009 | 08:23 PM
Rick's Avatar
Cool Re tag
Hi Craig, Sure Ill post it in the next day or so. Cheers Rick.
Old Oct 11, 2009 | 08:25 PM
Land Yacht Captain
Thank you VERY much!!!
Old Oct 11, 2009 | 10:59 PM
  #31
Rick's Avatar
vin plate
Here it is Craig.
Old Oct 12, 2009 | 05:47 AM
  #32
Land Yacht Captain
THank you very much.
Old Oct 14, 2009 | 07:58 PM
  #33
HolidayCoupe's Avatar
Awesome car!!
Old Oct 15, 2009 | 01:00 AM
  #34
Rick's Avatar
Thanks. A few dollars to spend yet but itll be worth it.
KDW
Jul 16, 2021 02:39 PM
NTMD8TR
Paint
Sep 17, 2014 09:45 PM
jdana24
Jul 25, 2013 11:15 PM
mv213
Sep 4, 2009 08:10 PM
IDAS 69
Dec 14, 2008 08:07 AM
