No Headrests to headrests
Old Mar 20, 2016 | 03:18 PM
kevdog442's Avatar
Member
Is it possible to install headrests on 68 bucket seats that don't have any? I don't know what's inside as far as provisions or if there is any.
Old Mar 20, 2016 | 06:29 PM
2blu442's Avatar
Hi Kevin
I've never done it, but believe you could. The 1968 seat backs have the metal frame that you could put the plastic head rest mounts into. But I don't know if you could use the more common 1969-72 head rests or need the rarer 1967-68 head rests. Below are some pictures, check them out and if you have any questions let me know. John
Here's a 1968 seat back with the cover removed.
Then here's a 1969 seat back with the cover removed. Note the black plastic tubes for the head rest rods to go into.
Then here's a set of 1967 seats with the early style head rests. I believe these are the same ones used on 1968's. Note how they fit over the seatback more than the 69-72
Old Mar 20, 2016 | 06:30 PM
Convertcrazed's Avatar
ck out the parts place....they have a hardware kit for that
Eric M
Old Mar 21, 2016 | 02:53 AM
kevdog442's Avatar
Member
Great information, thanks. I wanted to make some 68's look like '69s but I had forgotten that the seat release button is different. Idk may still try it.
Old Mar 21, 2016 | 04:31 AM
rob1960's Avatar
I'm going to add the head-rests on my '68 when I get around to recovering the seats. I got the installation kit & headrests from Ecklers chevelle. The kit comes with the 2 plastic tubes & the '70-'72 style latches for 1 seat,so order the '70-72 headrests to match the latches. The few '68s I've seen with the rare A81 optional factory headrests looked like the newer '69 up style ,not the pointy'66-67 type. I will say the aftermarket headrests are just ok!& they only come in black. If you can try to find a nice original GM pair from someone. The GM originals have real vinyl that was formed over a foam core, the repops are just hi-density black foam. Like I said they look just ok, not great! I was actually thinking of spraying them with SEM black vinyl paint & a satin clear top coat to try to give them a more factory look. SEM products are awesome, the stuff wears like iron & doesn't peel of flake off!
Old Mar 21, 2016 | 11:04 AM
RAMBOW's Avatar
Ben
Yes you can absolutely add them to 68 seats. They take the same HW & Tubes that were used from 69-72.
The 68 had unique lock bezels, but the 69 ones will work.
Differences between 69-72 headrests & locks had to do with which side the detentes were on the headrest legs. The repop ones come notched for all options.
fizzy55
Oct 10, 2009 08:46 PM
Graniteman
Feb 24, 2009 09:17 AM
mb197942
Oct 20, 2008 10:30 AM
h-bomb
Dec 10, 2007 02:04 PM
mrmike
Feb 17, 2007 08:02 AM
