New carpeting
Old Mar 18, 2026 | 10:53 PM
gmo1973's Avatar
New carpeting
Hi Folks
Well its mid March and time to get ordering! Im looking at new carpeting for my 73C/S black looped. My Question who to get it from? I was thinking Fusick or Jeggs. They look about the same, or is there someone better?
Any help is Always appreciated!!!
Old Mar 18, 2026 | 11:39 PM
Tri-Carb's Avatar
It is all made by ACC in Alabama and drop shipped to you . Buy it from the cheapest vendor.
Old Mar 19, 2026 | 01:32 AM
2qwk4u442's Avatar
Old'S-Kool
gmo1973, I'll be doing the same thing here shortly... Agree with looking around for best price but include looking at Rock Auto, each time I've priced ACC carpet they seem to be the best. (And usually you can find a discount code for Rock Auto here in the forum)
Old Mar 19, 2026 | 03:38 AM
Bfg's Avatar
Bfg
The jute backing isn’t as thick as the original, if your original jute backing is in good shape I would try to reuse it.
Old Mar 19, 2026 | 04:23 AM
Here's a supplier I've used before for seat covers. They sell carpet too. I'm not sure if they get their carpet from ACC.
https://www.automotiveinteriors.com/default.asp
Are you doing a concours restoration on your Oldsmobile?
Old Mar 19, 2026 | 11:07 AM
gmo1973's Avatar
New Carpet
Hi folks .Thank you for the response. It does look like it all comes from ACC
I am not doing a concourse resto but what I don't want for it to look like replacement carpet.
Also i am going to try and get my 6-way power bench fixed..I had it tested last summer and the front tilt is done.
Anything else I should be doing while the carpet is out?
Ken
Old Mar 19, 2026 | 03:57 PM
Tri-Carb's Avatar
Inspect for corrosion and consider sound proofing.
Old Mar 21, 2026 | 05:49 AM
jaunty75's Avatar
I purchased carpeting for my old cars from this site. Very pleased. Most recently, in 2023, I bought carpeting for my '73 Delta 88.
https://www.varkmotors.com/
Here's a few photos of the new carpet after installation.
Old Mar 22, 2026 | 12:10 PM
cfair's Avatar
I can recommend the undeylayment products from Dynamat. I used their Dynamat sticky rubber/aluminum backing product for sound deadening on a cleaned floor pan, and they have another foam product, maybe called Dynaliner, on top which serves as a cushion and probably reduces heat & noise yet more.
The products work, but are not as cheap as other alternatives.
Cheers
Chris
Old Mar 22, 2026 | 12:15 PM
70sgeek's Avatar
'72 Cutlass ragtop
ACC from Rock Auto - ACC makes a 'heavy mass backing' carpet version which is much nicer than the stock offering - you can feel the weight difference and it noticeably quiets the interior down. If they have it for your CS model, definitely one you should consider.
Old Mar 23, 2026 | 01:00 PM
gmo1973's Avatar
Thank you all for the feed back I will let you know who t go with !!!
Old Mar 24, 2026 | 08:39 PM
gmo1973's Avatar
Thank you Chris
I'm fearful of the dynamat.I going to stay more stock material.
Ken
Old Mar 24, 2026 | 10:03 PM
cfair's Avatar
All good. I just like closed cell foam better than sponge-absorbent jute.
Ctls442
Dec 27, 2025 07:46 AM
Laylow
Mar 13, 2025 07:14 AM
njhgv
Jan 3, 2022 08:27 AM
NDERISE
Jan 1, 2015 07:14 AM
jjokrm
Dec 27, 2012 06:35 AM
