interior rear quarter panels
From: from Wisc, then Texas, then Kansas, now back to Texas,
rear quarter panel , the padded upholstery area just below the rear quarter window on a ' 69 Cutlass convert, ... The new vynyl peice has a cardboard peice glued to part of it , while the old original peice has the card board also but it is also glued and rivited to the top curved metal part . Obviously I need to keep the top curved metal peice, so , do I remove the original metal peice from it's original card board, ??? and if so , how do I refasten it to the new card board ? OR, do I leave the original card board and curved metal peice together and just add (glue) the new card board over the old one ?
The correct way would be to remove the old curved metal part (called the rail) and install it onto your new panel.
I did this to the front door panels on my car, the concept is the same. Legendary reworked my rear panels for me.
You might get some rework hints from these posts:
https://classicoldsmobile.com/forums...tml#post162232
https://classicoldsmobile.com/forums...html#post66668
would a glue such as the Gorilla Glue work for gluing the rail to the panel ? How about using head liner spray type glue for the rest of the panel ??
eudaman
May 19th, 2013 05:30 PM
robvrobv
February 18th, 2013 04:32 AM
62radarlove
May 16th, 2012 10:15 PM
