Interior plastic panel paint dye code for 1971 442
Hello I need help I am restoring a 1971 442, it has Sienna Interior, I need help with the correct paint or dye code for the plastic trim parts such as
lower side vent covers any help would be greatly appreciated.
lower side vent covers any help would be...
Check the cowl tag for the interior paint code if you have the original color. Then find an SEM paint supplier to have them mix the color. I don't think you will find it in a rattle can so you'll have to use a spray gun.
The Cowl number reads TR 939 and I can't find that either
I merged your two identical posts. It's in your best interest to keep all responses in a single thread so incorrect info can be corrected. Here's TR939:
Here are the paint codes for the interior paint. I got mine from TCP Global.
