Interior Kits for 71 Delta 88?
Old Feb 26, 2011 | 12:15 PM
RPMRestoAndCustom's Avatar
Hey guys....I'm in the middle of a restoration on a 71 Delta 88 for a customer and I'm on to the interior at this point. Are there replacement seat covers and door panels available for these cars from any quality suppliers? I don't deal with a ton of Oldsmobiles so I'm not familiar with the best aftermarket suppliers for them. Thanks in advance.
Old Feb 26, 2011 | 12:27 PM
Gary's 2 442-S's Avatar
Gary
Give Legendary Interiors a call
http://www.legendaryautointeriors.com/
Old Feb 26, 2011 | 01:08 PM
Higgins's Avatar
www.smsautofabrics.com
Old Feb 26, 2011 | 02:50 PM
rocketraider's Avatar
Oldsdruid
You won't find a premade upholstery kit for a Delta. It's gonna be a cut and stitch job by the trim shop. SMS will be able to supply the correct interior fabric, but if it's vinyl a well-stocked trimmer may have it on the shelf, cheaper.
Lower door panels (the hard plastic section) are identical for all 1971-76 GM B-body cars of the same bodystyle. Black ones hold up well; the colors do not. Upper door panels are specific to the Division and model.
Old Feb 26, 2011 | 04:59 PM
To expand on Glenn's post, SMS will make repro door panels. They can mold and heat seam the vinyl per the originals. These aren't cheap and they take a while to make, but SMS does a nice job. A friend of mine had them fabricate the door panels for his 62 Cutlass convertible.
Old Feb 28, 2011 | 09:34 AM
Thanks for the info. For my custom stuff I normally use Everlast Auto Interiors here in NJ and they have always done right by me. I just figured I'd get direct replacements if they were available.
I pulled the whole interior today and the floor pan is shot front to rear. Anyone know where I can get a full replacement? Tried searching for a bit but B Body stuff doesn't seem to be super common.
Old Feb 28, 2011 | 09:49 AM
Good used is probably your only option. 1971-76 B-body should all interchange (C-body wheelbase is longer and thus so are the floor pans).
yeahbuddy
Dec 27, 2011 01:35 PM
ELISALAAM
Feb 11, 2008 01:38 PM
57olds
Oct 18, 2007 07:28 AM
Specman
Mar 16, 2007 05:59 AM
72RocketPower
Aug 11, 2005 04:51 AM
