instrument bezel/dash trim repair/replace
I am slowly repairing my way around my 1969 Olds 98 as I attempt to sell the car - I wish I had the room, but I can't keep 3 cars.
At any rate, the dash is good, but the plastic bezel around the gauges and the bottom wood-trim pieces need help. Some nut sack drilled a couple of holes for something.
JustDashes is great for the vinyl, but is no help for the chromed plastic and woodtrim pieces, or so I was told today, anyway.
Does anyone have suggestions for repairing those and refurbishing them?
I've discovered there are probably better sources for a new bezel and vinyl inlay. The vinyl from The Parts Place does not have any way to adhere it to the bezel but other sources have them with a metal backing that can easily be glued. You might try http://www.fusick.com/ if John's won't fit.
