instrument bezel/dash trim repair/replace
Old Dec 7, 2009 | 05:14 PM
wjustinmartin's Avatar
I am slowly repairing my way around my 1969 Olds 98 as I attempt to sell the car - I wish I had the room, but I can't keep 3 cars.
At any rate, the dash is good, but the plastic bezel around the gauges and the bottom wood-trim pieces need help. Some nut sack drilled a couple of holes for something.
JustDashes is great for the vinyl, but is no help for the chromed plastic and woodtrim pieces, or so I was told today, anyway.
Does anyone have suggestions for repairing those and refurbishing them?
Old Feb 4, 2010 | 03:23 PM
Bobac455's Avatar
I dont know about a 1969 but The Parts Place in Elburn, Il has everything you should need. Their number is (630) 365-1800. www.thepartsplaceinc.com
Old Feb 4, 2010 | 07:17 PM
2blu442's Avatar
I've got a 1967 and a 1968 Olds 98 instrument panels. I don't know if 1969 was different or kept the same shape/design. John
Old Feb 5, 2010 | 12:39 PM
Bobac455's Avatar
I've discovered there are probably better sources for a new bezel and vinyl inlay. The vinyl from The Parts Place does not have any way to adhere it to the bezel but other sources have them with a metal backing that can easily be glued. You might try http://www.fusick.com/ if John's won't fit.
71 Cutlass
Jan 13, 2017 09:35 AM
HonestDave
Jun 21, 2012 05:52 AM
eight_bit_micro
Jun 10, 2009 12:11 PM
rroth01
May 17, 2009 08:35 PM
rroth01
Apr 21, 2008 02:16 PM
