Inertior door handles. Got to give them a good yank
to open the door. Before I take apart door and try to fix, Is this an adjustment or am I am going to need to replace something in there. I searched thru thru service and assembly manual and didn't find anything.
72' CS.
72' CS.
I had a mechanism go bad and I had to replace it. Just make sure you get one for an Olds, not a Chevelle. I don't think Chevy used the arm rest base, so their splined stud is shorter and won't work with the base plate and arm rest. I bought one from one of the parts companies and had to send it back. Not sure, but might have been Year One.
A good dose of real lube like chain oil or white grease spray can do wonders for mechanisms like that also. The main latch over at the aft edge of the door, mainly, but might as well do all other things like window tracks while in there.
Exterior handle works real easy. Door closes nice and easy.
Inside handle I have to pull up hard and right at the top if I give the door some shoulder it opens. It's seems to be getting progressively worse.
How would the splined stud cause this? I was under the impression the issue was the linkage between the handle and the door latch mechanism was stretched or bent due to 40+ years of use, but I haven't been in there yet to check it out - been waiting for the temperature to drop below 100 so I can work on the car without getting heat stroke.
I'll trade ya. I'm waiting for temp to drop to -30 so I can park it for the winter and tear into it. BTW, I used to live in phx for 25 years. Maybe you've seen me around, used to have a 71 chevelle vert before the economy took a dump.
Can't say that I ever saw your car, but I worked with a Dave in Texas who had a drop top Chevelle. He worked in AZ before moving to TX then moved back to AZ. You didn't happen to work in the implantable medical electronics industry, did you?
Finally got off my *ss and took apart the door. I've figured out the problem is the clip that holds the rod to the panel is loose, Real loose. If I hold it in place the door easily opens.
I suppose you cannot get a new clip from OPG or similar places. Anybody have a remedy to fix this?
Also, the window was misaligned and I was going to fix it. However now when I roll it up with panel off it aligns perfect. Should I assume the panel is causing the problem and try and tweak it anyways?
HonestDave
June 27th, 2013 07:19 PM
