how would you fix this
Old Feb 28, 2018 | 05:54 PM
ropewrench's Avatar
I am going with a modern radio so I don't need the complete restore.
the guy butcher the hole
it was painted white then black, go figure.
is there anything that will loosen the paint and not eat the plastic?
I need to pull the climate controller too
any input on attack plan
Old Feb 28, 2018 | 07:45 PM
RetroRanger's Avatar
72 Olds CS
that is a separate part of the dash. If you pull the whole dash that lower plastic is another part you can find one from one of the parts sellers on here like oldspackrat and others
Old Mar 1, 2018 | 06:48 AM
ropewrench's Avatar
thanks
I am starting to dismantle the dash for clean up
Old Mar 3, 2018 | 10:31 AM
Wow, he jacked that thing up. Decent replacement parts is the way to go.
Old Mar 3, 2018 | 08:22 PM
ropewrench's Avatar
Who Why What were they thinking
the easiest way to work on the dash is with the seats, console, and shifter out. Carpet in. Steering column loose and gauges removed.
And that is just to replace the light bulbs
I had the seats and console in
The hacked radio hole helped get to the climate control.
I am not removing the climate controls just clean and inspect.
Windshield switch took 2 hrs
All of the plugs where stuck and my arms are scratched up
I'll take pict tomorrow
Old Mar 4, 2018 | 05:24 AM
Achcoastal's Avatar
my 70 c/s had an aftermarket radio and the dash was cut up almost as bad as yours. i was able to fabricate a plastic frame and install a factory looking radio without removing lower dash.check out my threads if you want to go that route... good luck
Old Mar 8, 2018 | 12:07 PM
ropewrench's Avatar
Looks good
You did a great job on making it look good
I am not planning on using the radio, but it would be nice if it turned on and make noise.
The radio I am using is smaller than the butchered Hole so I have to build out enough to fit it in then address the wood grain issue
What is the best way to remove the glue.
Old Mar 8, 2018 | 03:08 PM
You can buy the thin fake wood veneer (plastic) pretty cheap if you can fix up the plastic underneath it. I would assume the plastic would hide a lot.
Old Mar 9, 2018 | 05:41 AM
x2
Use JB Weld to reinforce the plastic dash where it's falling apart, then apply faux wood laminate.
I know they make faux wood laminate that matches what the factory used. I'm just not sure where to get it.
Old Mar 11, 2018 | 08:41 AM
ropewrench's Avatar
Thanks sounds like a great attack plan
So whats the best way to remove the old glue
heat gun softens it but too hot
Thinner loosens it
is there a trick
My thumb is growing a callus.
Old Mar 12, 2018 | 06:22 AM
Have you tried this?
Amazon Amazon
Old Mar 12, 2018 | 04:40 PM
Rocketguy's Avatar
Thinner loosens it
is there a trick
DX-440
Good luck : )
Old Mar 12, 2018 | 08:03 PM
ropewrench's Avatar
O wow
I have some of that
never crossed my mind
Old Mar 14, 2018 | 10:31 PM
ropewrench's Avatar
looks completely different now
I was too tired to vacuum just picked up the tools and loose pieces and called it a night
While I was under the dash I found the speaker. Its shot, it has a hole in the cone
Bought a heater core from Summit and it went in with out a problem.
R&R the spreader/bracket from the old on to the new one. Used Duct seal around the edge of the core to stop any future rattles.
R&R blower, tested and painted. Passenger fender is falling apart.
Found the Console extension, Still looking for the harness.
Started replacing lamps and ran out, ordered more.
Installed the map light and plugged the double wire and couldn't find the single.
The glove box light is no where to be found, switch is missing too.
Haven't figured out how to access the ash tray light yet, I love a good challenge.
Pulled the head light switch apart to relamp switch, blew a fuse and now none of the dash lights work, to tired to chase it down.
Fuse box in another cleaning day away.
Installed a dimmer switch and need bolts to attach it. I have no idea on the hardware
Carpet didn't get a grommet, so need a fix on addressing the finished look
Wood grain is metal backed. Went together easy enough.
Used the Tester pen to paint the silver back on the trim.
Messed it up 3 times.
Broke a post off the wiper switch bezel. One will do for now.
Broke the plastic yellowish backing plate that hold the top switch in place.
Crazy glued and went back in.
Greased the Climate controls
dielectric grease on all of the connectors lights and switches.
Ran out of hex head screws, I missed placed them or more than likely the guy before me didn't replace all of them. need to get my hands on some to hold the climate control in place.
Started to pull A/C vents and thought better not. I need to finish something before I start another.
Old Mar 14, 2018 | 10:35 PM
ropewrench's Avatar
I will finish the gauges when the climate controls and lights are working.
Need to touch up scratches too
Old Mar 14, 2018 | 10:38 PM
ropewrench's Avatar
The guy before me lost the ground plate from speedo to left gauge, so I made from copper sheet
Old Mar 15, 2018 | 10:10 AM
72 Olds CS
Looks a ton better!
Old Mar 15, 2018 | 10:22 AM
Rocketguy's Avatar
You've been busy; sounds like things are going as well as can be expected.
Be careful about using dielectric grease on your connections; it is not an electrical conductor.
If your using a stock radio you should use an 8 ohm speaker.
Old Mar 15, 2018 | 03:47 PM
ropewrench's Avatar
I am using a low end blaupunkt radio.
Sometimes the cheap stuff is harder to work with
the dielectric grease is to easily the remove them next time.
They where stuck and needed some force to remove them.
Old Mar 17, 2018 | 08:04 AM
midnightleadfoot's Avatar
ph_ckstick1
I know it doesn't help you now, but might in the future.
When working under dash I put on welding sleeves to keep my arms from getting cut up, an old sweatshirt sleeves cut off it works also..
I do the same when working inside a door also..
Old Mar 17, 2018 | 08:06 AM
ph_ckstick1
Originally Posted by Olds64
x2
Any cabinet maker will have it.. and most likely have scraps so you don't have to buy a whole sheet.
Old Apr 11, 2018 | 06:06 PM
ropewrench's Avatar
wraped up
Work got in the way
had to take a break from the dash repairs
replaced dash lights with leds, new lens on the gauges, new wood grain, bezels, and AC vents
rebuilt the console, "shifter arm is cracked going to look for another"
installed wiring harness, liner, gear indicator, chrome and wood grain
Old Apr 11, 2018 | 06:09 PM
ropewrench's Avatar
thanks 442crzy
thanks everything you sent has been put to use.
the parts work and look great
Old Apr 11, 2018 | 06:11 PM
ropewrench's Avatar
I am looking for the chrome around the console door and a shiftier arm
Old Apr 11, 2018 | 07:34 PM
442crzy's Avatar
PM sent on both parts
jag1886
Mar 17, 2018 12:12 PM
auto_editor
Jul 9, 2015 07:34 AM
Wyze
Jan 17, 2011 03:55 PM
ramos7
May 13, 2009 11:47 AM
1BAD68"S"
Nov 9, 2006 04:30 AM
