how remove back bench seat
Old Sep 21, 2010 | 09:09 PM
1983oldsmobiledelta's Avatar
Question how remove back bench seat
how do you remove the back seat in a 1983 delta 88 i got the bottom part out but how do you get the part your back goes against thanks
Old Sep 21, 2010 | 09:27 PM
Rickman48's Avatar
Look on the bottom - might be 2 bolts there!
Old Sep 22, 2010 | 06:05 AM
rocketraider's Avatar
Oldsdruid
I think by that time they were using some type of metal sprue that bolted under the outboard seat belt retractors. Seems like it takes about a T55 or T60 Torx bit and when I pulled the seats on my 74 Hurst I had to use an impact wrench to break them loose.
Old Sep 22, 2010 | 06:31 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Rocketraider is correct.
Torx bolts on the bottom flanges, and stamped steel hooks on top.
Unbolt the bottom, and slide it up off the hooks.
Old Sep 23, 2010 | 05:06 PM
its t45 and i got it out with just a breaker bar if anyone needs to know thanks guys for your help
Old Sep 23, 2010 | 06:50 PM
Oldsdruid
Aight den Muscles Malone!
I tried a ratchet and a breaker bar, and all either of them would do was get cocked in the bolt head and twist out. Sez me, I got sumpin for ya!
When that CP impact hit 'em...
nottyleradams
May 29, 2014 08:05 AM
Tony72Cutlass'S'
Feb 2, 2012 09:15 AM
Sailor
Feb 28, 2011 01:24 PM
richeyb
Jul 18, 2010 07:44 PM
Mason
Jul 21, 2009 06:56 AM
