How many screws hold this panel?
Old Jan 5, 2021 | 08:17 PM
724drcutlass's Avatar
Rookie question. I'm trying to install a temp gauge where a previous hole was cut. I need more access behind dash. I see the one screw to the right. Is there any more? It's a 72. Thanks
Old Jan 6, 2021 | 07:18 AM
RetroRanger's Avatar
72 Olds CS
I think the screw on the right is just to hold the cover over the column. I think the part on the left is a part ofthe dash.
Old Jan 6, 2021 | 07:47 AM
^^^THIS. That panel is welded into place. You aren't removing it without a torch. There are two screws that hold the plastic closeout panel under the steering column.
Old Jan 6, 2021 | 08:19 AM
Thanks for the info 👍
Old Jan 6, 2021 | 09:40 AM
72 Olds CS
If you cant getthere from underneath, the guage panel above is easy enoughto remove and may get you theaccess you need.
Old Jan 6, 2021 | 02:23 PM
jaunty75's Avatar
Ten. Four to hold the panel in place plus the six more you'll need when you inevitably drop some while you're screwing them back in and they roll away where you can't find them.
Old Jan 6, 2021 | 07:38 PM
true! 😁
dynamic63
Body work
Feb 8, 2019 12:24 PM
PM70
Dec 13, 2016 10:22 AM
denf221
Oct 18, 2014 10:32 AM
Eddie Hansen
Body work
26
Aug 13, 2012 08:41 AM
Aceshigh
May 11, 2012 10:51 AM
