Rookie question. I'm trying to install a temp gauge where a previous hole was cut. I need more access behind dash. I see the one screw to the right. Is there any more? It's a 72. Thanks
I think the screw on the right is just to hold the cover over the column. I think the part on the left is a part ofthe dash.
^^^THIS. That panel is welded into place. You aren't removing it without a torch. There are two screws that hold the plastic closeout panel under the steering column.
Ten. Four to hold the panel in place plus the six more you'll need when you inevitably drop some while you're screwing them back in and they roll away where you can't find them.
