How to install door panel carpet insert?
Old Apr 3, 2010 | 03:43 PM
yeahbuddy's Avatar
My 68 Cutlass has 8" door panel carpet inserts. The drivers side is missing the carpet and I want to fix that but I am not sure how the carpet connects. I've down replacements on RockAuto for $30. Does it stick with glue? Any idea if its precut?
Old Apr 4, 2010 | 07:16 AM
Lady72nRob71's Avatar
The carpet will glue to the panel with contact cement.
Choose an automotive grade cement that will withstand high temps...
Try to scape or sand off the original glue residue from your panel and clean it well first.
Not sure if the Rockauto pieces are precut, but even if not, you could make a cardboard template and trim to fit. A sharp razor knife will work best.
If they do not fit (too small), Rockauto has a very good return policy - no risk there.
I think OPG and Legendary sells the carpet inserts also.
Old Apr 4, 2010 | 11:05 AM
yeahbuddy's Avatar
Great. Thank you for that info!
milesmonte
Mar 23, 2015 07:31 AM
onofre442
Dec 1, 2013 10:36 AM
69442murph
Mar 24, 2013 10:00 AM
defiant1
Apr 30, 2012 07:53 AM
400mphpc
Jun 25, 2010 04:19 AM
