Horn contact
Horn contact
So I am in need of a horn contact for my sport wheel and am looking for one on ebay. I am looking at one that lists it is for:
67-81 CORVETTE PONTIAC FIREBIRD HORN CONTACT KIT NEW GM and lists the applications below:
1967-1981 Chevrolet Camaro
1967-1981 Pontiac Firebird and Trans-Am
1967-1982 Corvette
76-81 fits most Chevy and Pontiac cars.
Will this work for a 72 Cutlass with the sport wheel?
1967-1982 Corvette
Sport Wheel Contacts
Are you looking for the piece that is held to the hub with screws and clips to the horn button? If so, you need something like this:
http://cgi.ebay.com/ebaymotors/67-68...2em118Q2el1247
If you need the small spring and plastic piece that makes contact with the steering column pin then this is what you need:
http://cgi.ebay.com/ebaymotors/GM-Ho...QQcmdZViewItem
If you just have a wheel, hub and horn button then you probably need both!
John
John
So I bought the spring kit but the horn will not sound. If I place a small scredriver in the place where the spring goes the horn works. Could it be that I got the right spring kit? The spring from the original delux wheel has a larger spring than the one I got. Can I make the one from the deluxe wheel work? And the contact pin that it came with seems to be a little short. Do I have any options?
Lady72nRob71
September 13th, 2010 05:45 AM
ccchrome
February 13th, 2010 03:30 PM
