Glue Removal and Plastic Prep for Dash
Old Sep 6, 2018 | 12:50 PM
friesjh's Avatar
Hello all,
I just purchased new wood grain for both my cars. I have removed the old wood grain from my black car. I was able to take a scraper and got the high spots of glue/adhesive removed from the dash. There is still a film or residue on the dash. What should I use to remove this or do I even need to worry about this? H&H said to use a 3m adhesive to install the new pieces, but I want to make sure the surface is cleaned, prepped and ready to go for the new wood grain pieces.
Old Sep 6, 2018 | 01:35 PM
Oldsmomick's Avatar
Adhesive removal-dash
I would think that 3M General Purpose Adhesive Cleaner, #08987 would work well and also be compatible with the new 3M adhesive that H&H recommended. The label says that it will not harm cured paint, but that it may mar lacquer finishes.
Mick
Old Sep 6, 2018 | 02:07 PM
35tac's Avatar
I have used the 3M product mentioned. Works fine however when I used it I would spray a small portion of a rag and rub the area carefully. Worked fine taking off previous adhesive when I replaced weather stripping.
Wayne
Old Sep 7, 2018 | 05:13 AM
friesjh's Avatar
Great thanks all!
yeahbuddy
Nov 9, 2012 04:56 AM
skryla
Jul 22, 2011 12:51 PM
kjr442
Jun 29, 2011 10:16 PM
toro455
Jul 2, 2010 05:19 AM
70redvert
May 5, 2008 08:58 AM
