Gear Indicator Gauge
I pulled my cluster to solder in a full time connection in order to fix a tach issue and I cannot figure out where to re-apply the tension spring behind the gear indicator. The spring loops through an eye hole on the cable but where does it connect in the rear?
Thanks!
Thanks!
Flye
April 25th, 2011 08:08 AM
