Floor pans surface rust and paint
Old February 10th, 2018, 07:58 AM
Andrew83's Avatar
Hello people, I'm currently working on the floor pans of my 73 the original carpet padding ect was beyond saving so I have roped it all up. Glad I did cause the low spots were beginning to rust! Nothing has eaten completely through just surface cancer.
Few questions.
1 does rust stop solution work?
2 what do you recommend using for sealant where all the seams connect. GM used some sort of caulking?
3 what type of paint do you all recommend using once I've addressed the rusty spots?
4 where's the best place to order padding + carpet to place in my 73 cutlass S optioned 442?
Thanks just figured I'd ask ppl who have done this before.
I had planned on using rustoleum primer and gloss black rattle cans to paint unless otherwise directed. Wondering if painting floor pans black will be a bad idea for heat purposes. The interior is all black.
Andrew83 is offline
Old February 10th, 2018, 08:16 AM
4speed455's Avatar
I would consider Por-15 products. If directions are followed it will stop and prevent rust from growing.
4speed455 is offline
Old February 10th, 2018, 08:18 AM
Andrew83's Avatar
That's exactly what I have as a stop rust solution.
Andrew83 is offline
Old February 10th, 2018, 02:04 PM
cherokeepeople's Avatar
3m makes a body seam sealer #08656.comes in a quart can you can use a putty knife or brush it on.
cherokeepeople is offline
Delmont 88 PA
Body work
May 25th, 2012 09:28 AM
Del70
June 3rd, 2011 01:01 PM
Del70
May 22nd, 2011 01:31 PM
shaks 442 clone
February 14th, 2008 11:27 AM
t_visker
December 29th, 2006 08:59 PM
Quick Reply: Floor pans surface rust and paint
