Door Water Shield for 1964-1967 Olds Cutlass
Old Feb 2, 2022 | 10:42 PM
Gerald Nickels's Avatar
Just don't want to pay $155 for plastic shield is there a material I can use on doors and back panels of a 65 Cutlass ?
Old Feb 3, 2022 | 02:23 AM
ART T's Avatar
There are a few vendors on ebay that have reasonably priced shields. You can make them out of plastic sheeting that is 6mil or thicker.
Old Feb 3, 2022 | 04:47 AM
35tac's Avatar
I replaced the shields on my 66 Cutlass vert. I used 3M Strip-Calk to reset the shields. The factor adhesive was lightly used to save time and money. I cleaned off all of the old stuff and was generous with the new strip with only a few open spots. Prior to that clean all the vents and any dirt deposits.
Wayne
Old Feb 4, 2022 | 02:23 PM
RAMBOW's Avatar
Ben
Just get some heavy MIL plastic sheet from a HW store and cut to fit. Nobody is ever going to be able to see under the door panels to know if you have "date correct" brown/black wax paper sheets in there, and it will serve the same purpose just fine.
Old Sep 3, 2024 | 03:59 AM
radiofellow50's Avatar
Wayne: Maybe dumb question about the water shield and insulation ( I have to replace mine on my 75 H/O), Does the water shield go on first, then the insulation, which I'm kind of assuming, but if it's like a house, ...the vapor barrier goes on last? :-)
J1978
Jul 3, 2021 08:04 PM
scott_442
Apr 16, 2014 07:45 AM
at3reg98
Apr 28, 2013 08:55 AM
ddx77
Jun 24, 2010 10:49 PM
dynamic88
Feb 11, 2007 09:27 PM
